Unfortunately the news page info doesn't answer my question. When I follow the instructions to see the version my Q400 Pro is via the ISI screen , it says Aircraft MJC84- 1020B. Is this the correct version for P3D V 3.4? I believe I installed this update a couple of years ago.
For P3D v3.4 the version you are seeing on the ISI during power-up (1.020b), would be correct....and it should also be the corresponding installer/patch number which you should have available in your User Area.
OK Thanks. That was why I was confused, because when I went to the User area, it said under "Patches and Updates"
Must be a really complicated question>>>>>
@bobsk8
We do have personal lives as well>>>>>
The information you seek is readily available via our News page.
http://majesticsoftware.com/mjc8q400/news.html
MJC8Q400_PRO NIL
