Latest version of Q400 for P3D version 3.4
I want to make sure I have current version of Q400 for P3D version 3.4 Anyone know what I should see when I check version in the cockpit
  • Must be a really complicated question>>>>>
  • @bobsk8
    We do have personal lives as well>>>>>
    The information you seek is readily available via our News page.
    http://majesticsoftware.com/mjc8q400/news.html
  • edited December 2018
    Unfortunately the news page info doesn't answer my question. When I follow the instructions to see the version my Q400 Pro is via the ISI screen , it says Aircraft MJC84- 1020B. Is this the correct version for P3D V 3.4? I believe I installed this update a couple of years ago.
  • For P3D v3.4 the version you are seeing on the ISI during power-up (1.020b), would be correct....and it should also be the corresponding installer/patch number which you should have available in your User Area.
    OK Thanks. That was why I was confused, because when I went to the User area, it said under "Patches and Updates"
    MJC8Q400_PRO NIL
  • Ok... This would have been the latest installer for the P3D v3.4
