Issue with Alt dial [RESOLVED]
I have recently upgraded my dash 8 to the 64 bit version to use with prepar3d v4. Unfortunately I have an issue with the alt sel knob, when I scroll it goes up a little bit but then always jumps back down to 0. I have tried reinstalling, i also have the latest patch etc but nothing fixes it. Any help appreciated.
I'm experiencing the same issue after having to reinstall the entire system/sim. Used to work perfectly before the reinstall. So it's good to know I'm not the only one.
Might be some Windows 10 / NET framework issue since it used to work before my new installation. Would also appreciate help on this issue.
For me the solution was to set the units in P3D V4 to hybrid (feet/milibars). Was set to metric before. Solution is stated in the faq section.
This issue of the selected Altitude is jumping back to 0 is corrected by: Modifying the units setting to feet+inches, or feet+millibars within your simulation platform settings
