A couple of FMS qustions
P3dv4.
Navigraph updated.
1 . Between ENBR and ENCN - at a point the aircraft does not follow direction to next waypoint. It continues straight head on the same heading. The PFD do switch to next waypoint.
I have to use HDG sel and DTO to get back normal FMS.
Tried this flight several times, same error. I build the flightplan manually no fancy create and dump into FMS.
VNAV does not activate. (No movement) Could be a part of error mentioned above.
To be sure:
When do you hit the vnav button?
Prior to the cursor starts to move down?
When it starts to move-
or when the cursor pass center?Where to find info of ILS freq and course on FMS?
I found it before, but now I am not able to find the page again.
Thanks.
I did reinstall.
Works fine now - Both the waypoint change and erratic vnav activation.
Thanks.
