Where can I get 1.02a???
My purchase was through the Just Flight store and I am having a difficult time finding 1.02a. The downloaded version is 1.02. Please help.
Login to support->User Area section on our website and download the version the required update.
Where to download the 1.20a? I am signed in and purchased only the 1.20 via simmarket. Please help! Thx
Did you by chance see the previous post?
Yes, I see the post AND red it!
Neither able to login anywhere nor getting a chance to have an action when clicking on "user area". But thx or your fast answer anyway...
User Area Page:
http://majesticsoftware.com/mjc8q400/support.html
Re: Chubaka's last comment, out of interest I tried to log into the User Area - to check out any update) and failed to do it from my PC where my Sim programme and aircraft add-ons (like the Majestic Dash) are installed. I am able to do it from my laptop. Both are running Win10, so I assume the problem is with non-compatible virus / security progs.
Andrew
As far as I can tell http://majesticsoftware.com/mjc8q400/support.html "User Area" is non functional - click but nothing happens. Similarly the "Forum" button, in the list area under FAQ doesn't work, although the one at the top of the page does.
Just tried and both "User Area" and "Forum" (both button and top of page) work for me. I was able to log into User Area and see my licence status etc.
OK jb955 - must be a browser issue. Thanks
Andrew
I'm using Chrome on Win 10, if that helps...
