Order not found [CLOSED]
Just bought the upgrade to the Pro version at JustFlight however after removing the pilots edition and starting the installation of the Pro version I get the message order not found.
Is this normal or should I wait for a day before my order at JustFlight is registered into your database.
  • Apologies for the inconvenience that this delay is causing. Kindly send us an email to our Support Dept. (support (at) Majesticsoftware (dot) com Be sure to include your credentials and supporting information regarding your purchase.
  • email send.
  • Thank you
