Auto Pilot Issue
During flight, when I change to outside view, the auto pilot disengages. Can anyone direct me to a cure?
I'm sure this was raised in the old forum but I haven't been able to find anything on this subject.
Dasher
Dasher
For what it is worth, after googling my problem (above) I discovered the Q400 ini has joystick settings. I had set my stick view button to the same as Majestic had set the Auto Pilot Disengage. I only disengage the AP with the mouse so I took out the appropriate line(s) in the ini and now I can look about without AP turning off.
Now I only need to re-visit and re-learn the VNav notes & I'll be ok.
Dasher
