MJC Loads in Dark Panel
I just upgraded to P3Dv4.5. Loaded all my PMDG aircraft with no problem. Last night I reloaded the MJC and set the control panel up to include Ready to Taxi. Now, when I open P3D with a flight for the MJC to fly, it only opens with a totally dark panel, no sound, and the outside view shows it about two feet off the ground with the gear retracted. I closed out and reset the Control Panel. No change with trying again. I used a fresh download from SimMarket. Have flown the MJC for years and this is a first for me. The only change I made was in the .ini file to reduce the sound levels so I can hear Radar Contact. I have uninstalled the aircraft until hearing from you. Take care,
Mike Nicholson, Jetline Systems PC, 4.20 Intel 4 Core i7-7700k CDU, Nividia GTX 1060 6GB card, 32722 mbs memory, Windows 10- 64bit, Prepar3D v4.5
Re-install the aircraft using Administrator Rights by right clicking on the installer. the issue you describe is indicative of a protection issue (usually driven by an improper installation or in some cases a Window 10 update)
OK, but I have discovered another problem I need to rectify first. I have a whole bunch of programs I have purchased at SimMarket. Normally, I am not the Village Wizard, but am not the Village Idiot either. This time, I went right past the 64 bit version and ended up downloading the 32 bit purchase. So, I am about to download the 64 bit and try it again. Will let you know. Mike
Well, I guess I have been the Village Idiot. 64 bit sure makes a difference. I guess I need to figure out how to delete some of these SimMarket purchases. I do appreciate your quick response, Mike
Glad to hear that you got it sorted out. Yes the 32 bit installation would have caused you nightmares had you not caught on to it.
