COLD AND DARK MEMORIZATIONS
Goodmorning everyone
can you tell me if it's possible to store everything on OFF from the COLD AND DARK position of the dash8? I'll explain:
from the COLD AND DARK position I find myself for example the **MAIN BATTERY **--AUX BATTERY..STBY BATTERY - still ON, the flaps already positioned at 15 ° - the IGNITION ENGINE START on NORM instead of OFF.
I would like to have the possibility of having stored everything on OFF when I start the program, is there a possibility?
thanks
Hi, have you selected the start state here (see picture)? I have no problems in this regard, Cold and Dark is also Cold and Dark. The only thing I have not found out yet is that sometimes the external power is already available, but sometimes it must first be requested.
Hi kroswind,
is it possible to change the cold&dark script? I would like to have the aft door open when I start the simulation. However in real life when I'm inside the cockpit doors are opened...
Thanks,
Alessandro
thanks Kroswynd
building a home cockpit and having (as in real life) all the systems on OFF I prefer to save as you say and reposition the aircraft on another airport after finding commands in COLD AND DARK that do not correspond to the physical SWITCHES of the home cockpit with the difficulty of remodulating the same command twice to have it synchronized to the SIM.
a question:
how do i go about recreating the SCRIPT like you said ??
thank you so much
I agree alleusai
Check the directoty "scriptLib" in your aircraft folder. There you will find a file named "ccColdAndDark.mgs". This is the file to edit. In that script you either can change values to be set or you even could add additional variables out of the variables list provided with the XML interface to set them to default values.
... and don't forget to backup the original file ;-)
And in case of an update by Majestic or at an re-installation you may get the original file back. So to keep also a backup of the modified file is also recommended.
Bravo Reinhard!
Thanks a lot,
Alessandro
