Nose wheel steering problem
went thru most of tutorial check list..after pushback, I could not steer with nosewheel using rudders or spoilers.
2 questions:
1; do you have removed the gear pins (must be stowed behind the the copilot seat)?
2; do you have set the NW Steering switch on (left panel at the pilot seat)?
We have modeled the Q400 to operate similar to that of the real aircraft, so the use of rudder pedals will not steer the aircraft as you would expect with most other simulated aircraft add-ons.
Kindly read the provided manual ControlPanelGuide (page 10) located in the "doc" folder of the mjc8q400 root folder.
The Control Panel (CPAN) is the heart of the aircraft functionality.
