P3d v4.5 Install issue
Normally I can nut issues like this but having some problems here.
I recently reinstalled p3dv4.5 after some time away and Cant get the Q400 Pilot edition to install correctly. I can open the aircraft in the sim but controls are hard over to the left, no sound, throttles etc not responding. Also strangely there is a shaking from viewpoint. No screens display anything and battery switch moves but unresponsive. Legit copy.
P3d 4.5 vanilla with Orbx Australia V2 installed
I installed 4x simconnect redistributes pictured but no joy
Any info appreciated.
Dale
Hello Dale,
For starters, have you installed the Q400 using Administrator Rights? Also, what version of the Q400 are running - 32bit (not P3 d v4.x compatible) or the 64bit which is P3D v4.x compliant?
Yes I installed using Admin rights. Good question on 32 v 64, I purchased in 2013 so originally 32 bit purchase. I downloaded installer from justflight yesterday and had P3d 3.3 and above as an option but no P3d 4+
Is there a separate purchase for 64 bit version?
Cheers, Dale
Yes there is. P3D v4.x will have t o be purchased as most of the code had to be re-worked to be compliant with he 64bit architecture. You should still qualify for the upgrade fee on their site.
Thanks for your Help, will upgrade now!
Cheers, Dale
