Dash 8 functional error
Hallo Simers,
I Installed the Dash 8 q 400 in my computer on fsx steam edition and dispite the fact that it started on the short of the runway it was ''dead''. I mean that the engines were off, the gears were up and the panel cold & dark. Please help meee
I want to add that the overhead panel looks black and I cant use any button
The issue you explain usually is the result of a protection problem.
Lets start by un-installing the aircraft and re-installing using Admin rights by right clicking on the installer. Be sure to disable your anti-virus for the installation process.
Thank you im gonna try it
it doesnt work...But I opened the cfg of the aircraft and it seemed like it had problem...It was empty in some areas where it should be full.For example near the word panel it had nothing and it was like this : panel = . Have you got any other suggestion ?
The aircraft.cfg may or may not be the issue, but it may be more beneficial if you provide a detailed explanation on how you are attempting to setup your Q400 regarding the installation.
