Control Panel disagree
It seems it's not possible that assets on Control Panel will be apply to the Q400 PRO
I've try every day pointed "Mass Fuel" to Kilograms and "Atmospheric Pressure" to hPa.
Pushed "Apply" and reloaded the aircraft, but no changes, and I need to have kilograms in fuel and hPa in At. pressure.
How can I do it?
Many tks in advance
Many Thanks ckyliu, that was the solution.
Simply solution for my dummy Head
Item solved, tks again
