Map Lights
Hi Support Team,
When I switch on the map lights above the little drop down tables at the left and right side of the cockpit, I can see that the light is on with the bluish tinge around the physical light, but there is no physical light splash onto the map table.
Ken
Will have another look at that but since there is nothing that is placed on that table the light does not serve a purpose as such. Assuming you are using v5, there have been changes to the light is handled and this be one of the affected modules.
Yes, sorry, V5. A lthough nothing is placed on the tables, the light added to the ambience on the fligthdeck.
Ken
