Landing gear will not retract
Hi
Just installed this into P3Dv5 and applied the fix
the plane now does not crash to desk top
However I can not get the landing gear to retract
This is the pilots version not the pro version so
Thanks in advance if you can help.
Best wishes
Bob
  • Look at the end of the video...
  • The landing gear issue is a glitch that occurs in all editions which we are attempting to get a proper fix for.. Are you experiencimg on every flight?
    While this method may be a bit of a nuisance it should work.
    1. Pause the sim when the even occurs
    2. Save the situatuin
    3. Load the saved situation.
  • Hi
    Thanks for the information
    I reloaded P3Dv5 and tried a second flight and the landing gear did indeed work fine.
    Good to know it is a know issue and being worked on.
    Best wishes
    Bob
    Is there a hotfix for the landing gear failing to retract? Pausing and restarting the situation causes a problem with VA flights.
    Thanks ... Richard
  • @RichW could you please contact support@majesticsoftware.com about this issue. Thank you
