HOTAS and AFCS Inputs mode question
Hello pilots!
I am trying to assign some autopilot modes to the buttons on my X-52 HOTAS
Reading the Variable Maps file, it seems that the AFCS _-> inputs.mode_button are the options that I need to use with AFCS_KEY_NAV 7 and AFCS_KEY_VNAV 3 options
I have read this post http://majesticsoftware.com/forums/discussion/560/afcs-mode-mapping-with-spad-next-help-needed but it doesn't work for me.
Other functions like these work perfectly:
; AP DISC
J0_b0 = AFCS _-> inputs.AP_disengage
; TCS Button
J0_b1 = AFCS _-> inputs.TCS_button
; GA_button
J0_b29 = AFCS _-> inputs.GA_button
What I can't understand is how to assign the button of my HOTAS to the function I want to use from the autopilot
I have tried using these but they don't work:
J0_b2,7 = AFCS _-> inputs.mode_button
AFCS _-> inputs.mode_button = J0_b2,7
AFCS _-> inputs.mode_button = b2,7
If I use this combination, IAS mode works nice:
J0_b2 = AFCS _-> inputs.mode_button
It recognizes the button that I want to use in HOTAS and assigns it to IAS mode but I would like to assign NAV, VNAV and APP modes
Excuse my bad english
Greetings and take good care
@Francis
which button is J0_2,7? (what's the comma doing there??!!)
Hello, @ha5mvo
As I explained in the first post, I am trying to assign some autopilot modes to the buttons on my Saitek X-52 HOTAS.
I read the post where @muberti explained how he had achieved it using SPAD.neXt, but directly in the Saitek X52 HOTAS it does not work
J0 is the Joystick, b2 the button taht i want to use and, separated by a comma, the number of function that I want to assign.
I hope this explanation helps you understand what I am trying to do
Regards!!
Just a little comment to avoid confusion: I don't use spad.next. I'm just trying to assign the Autopilot mode functions directly to the Joystick buttons, just like the ones I already have for the TCS or GA buttons.
Regards!
@Francis
Not sure, but maybe you should try J0_b2=AFCS _-> inputs.mode_button 7
I have the same problem as Francis. I can't assign any function to the button if function requires also a number. The question is: How to use "AFCS_->inputs.mode_button" variable to control YD switch on AFCS panel?
J0_b0 = AFCS_->inputs.AP_disengage - This works fine;
J0_b0 = AFCS_->inputs.mode_button - This engage IAS;
Are *.jcc files still supported?
There is a JoystickCocpitConnectorGuide.pdf which contains some examples (also with using *.jcc files) but I think that manual file is outdated.
