Doors on PRO version
Hello
Sorry for such a stupid question, but I have spend almost all morning trying to find a way to shut down the CARGO door on the PRO version. For some reason, when I press SHIFT+E+number the 2D versions of overhead, pedestal etc pop up.
The only keys that work are SHIFT+E for main door.
Thanks for the help.
Thanks... I believe I was mislead by internet, as many forums said the doors were not modeled on the FMS.
Understood! Thanks!
Unless you have other finctions bound to the default P3D assignments - CLT+E+2 for the cargo door and CTRL+E+3 for the rear pax door should work as assigned. however some users were having issues initiating this sequence - as it does however rely on proper timing.
I have found that when the green bar appears on the screen after pressing CTRL+E on can then press 2/3/4, etc.
