CPAN disagree
Sorry if this message was already send and read, I'm not sure of that.
Installed last Win10, and again same problem, CPAN does not change anything, I put fuel in Kgs instead Pounds and tmospheric Pressure in Hp, allways with administrator rights, reload Q400, but nothing changes.
Tks for any possible solution.
This issue has been addressed here:
http://majesticsoftware.com/forums/discussion/814/majestic-softwares-q400-is-now-prepar3d-v5-ready#latest
Tks kroswynd, but it seems the link referes to Prepar v5, anyway, the problem is solved, tks again.
Correct, as one would assume you were referencing V5 - this is the only platform whereby the CPAN has issues loading data.
Glad you got it sorted out
