Autopilot and pedestal comes dark
Hi all! When I am flying or preparing flight, the autopilot and the pedestal engine control becomes dark.
Anybody can help me?
Let's start by providing as many details as you can, unfortunately we'll need some background information to assist us in trying to determine what the cause of your issue may be.
System specs:
OS:
Simulator platform:
An image of the problem usually does also help
Q400 version:
I use W7 home premium
Intel core i7
Memory 12 Gb
CPU 920 @2,67 Ghz
64 bits
FSX sp2
Majestic Pro version
Thank you for your help!
This has happened twice to me. It happened when I changed to Spot View on FSX. After going back to/from Virtual Cockpit View it solved itself.
Annoying but it was solved by changing the view a few times.
A. System resources are pushed to their limit.
B. Anisotropic filtering is used instead of Trilinear filtering.
OR in some cases
C. Implementing the use of Steve's DX10 fixer, although this one may cause more of an artifact issue with the HUD upon reentering the cockpit, which again is momentary.
