Control panel resets alt. to mbar when inches was selected
Hi all,
I set up the altimeter in inHg, click Apply, and the altimeter is still in mbars. When I open the CP again, it's back to mbars.
What to do, what to do?
Thank you in advance for your help.
E.
Q400 Pilot ed., P3D v.5.1
Oh, and I did reload the A/C, close the sim, etc.
I found the answer in another post. It has to be run as an administrator. What did the trick for me was to right click on CP shortcut, select Propreties, Compatibility, then tick Run this program as an administrator. Et voilà. Those sims are so tricky.
