Big camera shake upon touchdown ....
Hello I have read all forums and cannot find a solution... On touchdown there is a very big camera shake but my landing rates are top ( -22 ...) I have removed all shake from EZDOK 3 with no success ... Can you help me ?
To be sure one should also check in with the developer over at the Flight1 forum.
Appreciate this is a long time ago but if anyone found the answer, I'd be gratefull for help.
This problem only occurs wjth the Q400 and EZDOK V3 in P3D V5 - and the EZDOK forum is no help nowadays. Somehow I need to remove all effects from EZDOk but can't see any way. Tried ebrything including the options in the manual and a reintall of everything - no go.
Thanks in advance
Sorry unable to help as I have not used that utility since switching to CPlane
You have your cameras set in the "Human" tab, set your Dash-8 cameras in the "Interior"
