Condition levers and pedals
Good day,
Somethink is wrong with my DHC8, as the condition levers move up and down suddently, also I do not touch any pedals during flight, but they also move, left or right every 10 or 15 seconds
All axis seem correct under FSUIPC.
I will apreciate any help because is fully impossible fly under these problems.
Tks a lot in advance.
I am going to ask the possible obvious, but have you checked to ensure that there are no other input device bindings within FSUIPC or more importantly in the simulator's default device configuration.
Providing that the input devices are all properly configured, one could also disable all input devices and see if the problem persists, and then add each device back. make sure to calibrate as well via the CPAN.
If this fails, then uninstall and reinstall the aircraft using Admin Rights.
Keeps us posted
No other imput devices within FSUIPC oe in simulator default config.
I´ll uninstall and reinstall the aircraft.
ok, keep us posted
