.INI file
Good day,
I need to modify the .ini file of my Q400 PRO in order to stablish "PEDALS_STEERING_EFFECTIVENESS = 2.5" instead of 0.5
Of course, I'm administrator of my PC, but whwn I try to save the modified .ini file, it's impossible.
Whow can I midify such file?
I work under Windows10 / Prepar3d v4.1
Many tks in advance
What application are you using for modifying the mjc84.ini? Something as simple as Notepad should allow one to change the parameters within the .ini file and save
Done!
I just move the .ini file to the Desk, modify it, save it and move back to C:\Program Data\Lockheed Martin\Prepar3Dv4\SimObjects\Airplanes\mjc8q400\ini
Tks for your answer Kroswynd
