Problem with the CPAN on Dash Q400
I recently took a break from Dash and when I went back to him and tried to run the Control panel, I was showing this error. I was reinstalling Dash and it didn't help. Please help
Are you installing the aircraft using Admin Rights by left clicking on the installer and selecting Run As Administrator?
Not sure what the error message is saying as it is not in English.
Translated text from the photo:
The application cannot be started because its simultaneous configuration is not correct.
More details can be found in the Application event log or by using the sxtrace.exe command-line tool
Do you have more than one copy of the Q400 installed, i.e. P3D v4.5 as well? Not easy to determine your issue as you have not really given us much to work with in terms of setup: OS, simulator(s), etc
Earlier I used FSX also on dash.
Yes I only have one copy of Dash.
OK, thanks for the update. So my question is, do you have FSX still installed? And if so, might you have a copy of the Dash installed for FSX. Normally there should not be a conflict between the two.
However, if you are running CPAN from a shortcut on your desktop that is still linked to the FSX version you could have an issue, but normally an error message of that nature is not usually displayed.
Failing to execute the full installation procedure will result in unexpected results
Thanks for keeping us posted.
