Saitek Pro Flight Yoke Push-to-Talk Deactivates Autopilot
I fired up this beautiful bird the other day and found a problem. I have the latest version of the Dash8-Q400 on P3D v 4.5 with the latest version. I fly on VATSIM and use the Saitek Pro Flight Yoke. Through VPILOT I have the red button (on top of yoke) on the yoke dedicated to talking with air traffic control. I discovered that when I press the push-to-talk the autopilot deactivates. I also use FSUIPC6 and no where does it reference autopilot. Here is a copy of my FSUIPC6 ini entry. The few times I flew this bird I did not encounter air traffic control so I was never aware of this problem. How can I fix this problem?
[Profile.Dash 8]
1=MJC8Q400_CJC
2=MJC8Q400_JZA
3=MJC8Q400_WEN C-FIWE
4=MJC8Q400_QXE
[Buttons.Dash 8]
3=P1,14,C66079,0 -{GEAR_UP}-
4=P1,15,C66080,0 -{GEAR_DOWN}-
5=R1,19,C65602,0 -{THROTTLE_DECR}-
6=U1,19,C65604,0 -{THROTTLE_CUT}-
[JoystickCalibration.Dash 8]
AllowSuppressForPFCquad=Yes
ExcludeThrottleSet=Yes
ExcludeMixtureSet=Yes
ExcludePropPitchSet=Yes
SepRevsJetsOnly=No
ApplyHeloTrim=No
UseAxisControlsForNRZ=No
FlapsSetControl=0
FlapDetents=No
ReverserControl=66292
Reverser1Control=66422
Reverser2Control=66425
Reverser3Control=66428
Reverser4Control=66431
MaxThrottleForReverser=256
AileronTrimControl=66731
RudderTrimControl=66732
CowlFlaps1Control=66162
CowlFlaps2Control=66163
CowlFlaps3Control=66164
CowlFlaps4Control=66165
SteeringTillerControl=0
MaxSteerSpeed=60
RudderBlendLowest=1
Aileron=-16383,0,512,16383
Elevator=-16383,0,512,16383
Rudder=-16383,0,512,16383
Throttle=-16383,16383
PropPitch1=-16384,0,512,16383
PropPitch2=-16384,0,512,16255
LeftBrake=-16380,16380/16
RightBrake=-16383,16383/16
OK I have found the entry in the .ini file. My question is do I delete only inputs.AP_disengage? Or both entries under ;AP DISC?
; Ailerons
;J0_X=FlightControls_->sensors.Aileron0_ADC
; Elevators
;J0_Y=-FlightControls_->sensors.Elevator0_ADC
; Rudder
;J0_Z=FlightControls_->sensors.Rudder0_ADC
; AP DISC
