GSX Level 2 Expansion
GSX published an expansion with ramps and passengers. Of course the ramps we do not need for a Q400
but do the passengers behave accordinly with an aircraft not using them, and board the aircraft as they should ?
Thanks,
Robert
Don't know....unable to comment on it at the moment. I picked up the package but have not had time to see how it works with the Q400.
Thanks kroswynd for taking the time to reply, I will be looking on my side for an answer.
yes, it works with the Q400.
Un
fortunately it is the Q 400 that doesn't work for me...
