Control Panel Issue
Q400 loads up ok into P3Dv4.3 and flys ok. However when I start Control Panel ( .as Admin) all boxes are blank and I am unable to type in any data( Passenger Nos etc)
Any ideas on what may fix this. I have tried a complete uninstall and re install of the Dash 8 with no success.
Uninstalled and right clicked on the .exe file.
Still the same results ?
Further comment on this problem,could this be SimConnect issue?
It could be, have you tried to re-install your Simconnect modules that came with P3D?
No ! Where would I find this module to re install it ?
Hi kroswynd,
Re Un installed and re Installed Q400 again, making sure I right clicked to install as Adminisrator!
Seems to have fixed the problem this time ??
Thanks for your help
Thank you for the update
