Rudder actuator test
what is the expected behavior when pressing the rudder system buttons on the front panel (24hr system check)? I thought with one system deactivated, rudders should still work and when both are deactivated, there would be no rudder movement?
With the current version of the training edition, the rudder moves even with both turned off. Is this a bug or am I doing something wrong?
Best regards
Adrian
Perhaps this will be of help:
https://smartcockpit.com/docs/Q400-Flight_Controls.pdf
Thanks, so if I get that right, than it isn't actually possible to completely turn off the rudder hydraulic support, right? If you press both buttons, the previously chosen system will be powered again?
To be honest, I don't know the correct answer to your question. Hopefully someone else with more knowledge will respond.
