125Hz set up for brakes, throttle quadrant
I'm not trying to flood the forum with messages, but.. I've done some research on the forum regarding 125Hz setups and have found several messages regarding the yoke and some buttons, but still looking for brake and throttle setups.
Does anyone have a full setup using 125Hz that they can share with me or a list of the variables that I would need?
Thanks,
Ernie
Brakes and throttle quad inputs can be handled directly from within the simulator based on your choice of input device binding.
You can try this YouTube source for some guidance
Thanks.. Unfortunately, the video only reflects what I had already tried. Ailerons, elevators, and the rudder are no issue. It's the quadrant that I wanted to try. I've found some messages on this forum showing variables, such a 'sensors.BrakeL0_ADC', but the feedback indicates that they don't work. Surely, there has to be a document somewhere that contains a list of values that can be used.
I had hoped that the 125Hz option might make the relationship between the Q400 and my throttle more consistent. As it is now, it's hard to maintain a smooth flow.
A small movement of my throttle may result in no movement of the Q400 throttle, but the opposite is sometimes correct. There are times I can move my throttle and the onscreen throttle goes in the opposite direction or jump like crazy. Sometimes the setting will look like it's okay then later the reading will change.
Landings can be hell, as the throttle won't stabilize. It's a challenge to keep it anywhere near the landing v speeds.
There has to be a solution or perhaps it's my crappy Saitek quadrant, but I bought a new one with no success.
I do appreciate the assistance though..
Ernie
It looks like any variables are in the file that you pointed me to, so I'll give those a go and see if I have any luck.. Again, thanks for all of your assistance. I really do appreciate it.
Ernie
