1.020a not able to use this patch for download edition from fs pilot shop.
edited October 2018 in Customer support
I have a FSX download version (Pilot edition) from FS pilotshop. and I would like to update it to the latest version. However, in my user area, there is only a patch for the box version. I can't use this patch because it is asking for a cd key.
What to do?
Thanks in advance for any help.
//Arthur
  • Hi Arthur,
    You should not include your purchase info in a public forum posting. It opens up, not only the software, but your account info to piracy.
    For support on purchase matters, it is best to contact Majestic software by emailing them at; support (at) majestic (dot) com.
    Replace the bracketed words with @ and a .
    Point them to this post and they can hide your order details.
  • Thank you. I have mailed them.
    //Arthur
  • Unfortunately, the patch that you are attempting to use is for the 64bit Prepar3D version of the Q400. Write to our support department with an explanation of the issue.
  • Ah, oke. Now I understand. I have the 64bit Prepar3d version as well. At this moment I'm not using Prepar3D. Thanks for your help.
    //Arthur
