Strange happenings !
I have just upgraded from P3D v3 to P3Dv4 (64 bit) pilot addition.
I uninstalled my old version from V3 before installing my new purchase of the Dash into V4.I then used the 1.20 A patch to update the 1.20 download from FSpilot shop.
Everything seems to go well until about 5 minutes into the flight when my views lock up (using EDokv2).
I thought it may have been a EZdok problem but I have noticed that when this happens EZdok and also Activesky disappear from the add-on list.
If anyone has any ideas please ?
P3d v4.3
W10 64 op sys
Steve
  • Are you able to operate the Q400 with both addons (activesky and EZDOK) disabled?
  • All sorted thanks ;)
    It was not any fault with the Dash.
    It seems that i had uninstalled another aircraft and when i checked the DLL + XML files that aircraft had left behind an entry .After this was removed everything is now working fine :)
    Sorry for wasting your time
    Steve
  • Good to hear that you are back on track.
    Thanks for the update Steve
