Unable to calibrate honeycomb bravo w/ -8 control panel
Hello:
I am attempting to configure my honeycomb bravo throttle using the MJC8 Control Panel.
My throttle handles are in the exact same physical position but in the control panel, the "power lever left/right" postion inputs give 2 different figures.
Also, even though I'm moving the throttles smoothly and insync, the throttle handles in the cockpit move seperatly.
PS-I do know that in the picture below, different position figuers and in the MAX/DETENT/IDLE/DISC/REVERSE. I was simply trying to play with settings.
https://imgur.com/4DKImjI
https://i.imgur.com/4DKImjI.jpg
[url=https://imgur.com/4DKImjI][img]http://i.imgur.com/4DKImjI.jpg[/img][/url]
  • " PS-I do know that in the picture below, different position figuers and in the MAX/DETENT/IDLE/DISC/REVERSE. I was simply trying to play with settings."
    The numbers for each throttle axis will be different owing to the differences in the individual potentiometers. It's not something to worry about.
    When calibrating your throttle quadrant, it is important to ignore the power levers in the Q400 VC. They will sync with the Bravo after the calibration is finished. (providing it is done correctly)
    Regards, Craig
