Control Panel Ready to Taxi block does not work
Hi, I just downloaded the Majestic 8Q400 Pro v5. After completing the Control Panel Flight Config and checking off the Ready to Taxi block, it's not working for me. This is a brand new Jetlines PC I am setting up. It's Windows 11 and everything except the Ready to Taxi works as expected. This is the first time in all the years I've flown the Dash 8 this has happened. In reading the Forum, I see where this may be related in getting v-5 installed. I'm hoping maybe there is a button or switch somewhere I just need to turn on. I do note that every time I check this block, the next time I open to Ready to Taxi it is unchecked. Appreciate the help, Mike Nicholson, San Antonio, TX
With no response to my first Discussion, hoping it works this time.
  • I thought this was a pretty basic question. Is there another place I should route my question to? Mike
  • I would suggesting going into the control panel when the si. Is not running and set the state and be sure to click on the Apply button and then run the sim.
    Another option is going into the mjc84.ini and making the change there. There are several discussions on the forum regarding this since Lockheed made some changes out control panel does not work like it is supposed to.
    Hopefully we can find a better way to integrate this in the future.
