BSOD on exit
I had recently reinstalled my OS. After that, every time I try to close the sim after flying the Q400, just clicking the close button throws a BSOD. This started happening after installation on Q400 and only with Q400. Other aircraft are fine and do not throw a BSOD.
The dump ties the error to HAL.dll. Also, my throttle on my Logitech X3D Pro is a bit glitchy due to its age. It keeps moving back and forth inside the sim. Could these problems be related? Can my joystick be the culprit to crashes? If so, why doesn't it crash with other aircraft?
I have the Pro Edition and P3Dv4.4 Academic, running on Windows 8.1 fully updated.
Please advice. Thank you.
