No sounds on V5
Hi I have no sounds on the q400 on v5 hf2. I have sound on any other aircraft but the majestic. I already reinstalled it a couple of times with no change. Already tried all sound options on the sound panel. No external or internal audio. Downloaded the installer from simmarket v1.021.
Its my second time trying to fly the majestic and always an issue occur like blurred displays.
Win10 1903.
P3d v5 hf2
Carlos Gomez
  • I have the same problem - I use a Hands-free Headset (Taotronics TT-BH040)
    Hope somebody can assist
  • This link may be of help...there have been several discussions regarding sound use the SEARCH function and see if one of the discussions may apply to you .
    Try this one for starters:
    http://majesticsoftware.com/forums/discussion/comment/2417#Comment_2417
  • Got it working
    I set the Sound on the MJC8 Q400 Control Panel as follows
    Sound Map - 3D
    Entertainment - All on
    Global Settings - Global Focus ON & WIN7 Compatibility Mode ON (I have Windows 10 installed)
    Device - Mai Playback - Mapper & Headphones Playback - Mapper
    Hope this will help
