Visual Extension package installer error
Bought the extension package on simmarket.
But I cannot install it due to this error.
Im pretty sure that I have the PRO 1.021 edition. I installed the 1.021 rev 2 patch last time it was released.
Any steps to troubleshoot or things to try?
Thank you!
  • i am having the same error, after reinstalling mjc8-400-Pro-1_021_x64-inst.exe i am getting the error "No order found" after entering my credentials (Visual Extention Setup).
  • I'm going to try and get this and install in a couple hours. Will add my feedback here. So if this installs over the previous q400, I assume the 125hz controls in our INI files will stay in tact?
  • everything worked ok for me.
  • Can confirm, reinstalling the plane with a fresh download fixed the issue. I guess just replacing dll to upgrade previously was not getting picked up by the installer and it was thinking that a wrong version was installed.
    You have to use your simmarket order number for the Visual Extension Pack. Not the order number of your Majestic Dash 8 :)
  • there is no order Nr. in Simmarket.
  • here is the screenshot from simmarket.
    It is present in your confirmation email from simmarket :) right in the subject name of the email.
  • there is only th Order#. I have opened a ticket at simmarket.
  • I am getting old ... I have a differnet email Address on simmarket, Problem solved
  • If you are still having issues...
    Kindly have a look at this post and see if some of the suggestions may be of help.
    http://majesticsoftware.com/forums/discussion/1171/visual-extension-pack-installer-error#latest
