Q400F
Downloaded the Q400F external model but no read me to tell me what to do with it.
Can you point me in the direction of some instructions please?
Lee
  • edited July 2019
    Put the .mdl file into the same directory as the original, default one.
    If you open aircraft.cfg, you can see a line "model=" for each livery.
    For freight liveries, you can change it to "model=F" so it uses the freighter model.
    E.g. FedEx livery from avsim: https://library.avsim.net/download.php?DLID=182905
    [fltsim.XX]
    title=MJC8Q400_FEDEX
    sim=MJC8Q4
    model=F
    panel=
    sound=
    texture=FEDEX
    kb_checklists=
    kb_reference=
    atc_id_color=0xffffffffff
    atc_id=NTETP
    ui_manufacturer=Bombardier
    ui_type=MJC-8 Q400
    ui_variation=FEDEX
    ui_createdby=Majestic Software
    description=Majestic Software Dash-8 Q400 FEDEX by Peter Brown
    atc_heavy=0
    atc_airline=Private
    atc_flight_number=
    This is just an external model without windows. It does not change the load manager or anything else. So when loading your Q400 freighter, you have to use an "85kg passenger" unit of mass for your cargo :-) . No big deal, though.
