Landing gear inop
i saw that are more users with the same problem. just to add one more.
3 virtual airlne fligths canceled because of this.
Did you remove the Pins before starting the engines? check the Sack behind the copilots seat (easy to see from the captain seat) If the sack is stuffed and the "remove before flight" bands hanging out, then everything is ok. If it is empty, click on it, then the pins are removed and on board.
Clicking on the sack only works as along as at least one of the aircraft‘s doors is still open.
@Lindbergh that's correct, i thought this is obvious that the door must be open to get the pins in lol
