eclipse yoke button
On my CH Eclipse yoke there is a button set to disconnect the AP. I have not programmed this into P3D. I use that button for voice on Vatsim. Any idea how to disable this on the Q400? It only does this on the Q400.
Darcy
Darcy
Check the MJC84.INI file in the INI directory in your airplane folder for the following section:
You might have an entry for the AP disconnect button there active. Put an ";" in front of the line:
; AP DISC
;J0_b1=AFCS_->inputs.AP_disengage
By that it's disabled.
Thanks!
Darcy
