Scripts folder and Q400 variables [RESOLVED]
The Special Features document explains how to assign Q400 controls to j'stick buttons by
using Q400 variables contained in the " ..\scripts\varList.xls. " file.
  The varList.xls file has apparently been replaced by a " VariablesMap.xlsx " and I can't
find any AFCS entries in it.  I am hoping to be able to make the following assignments
to my joystick buttons >>
J0_b0=AFCS_->outputs.AP_diseng_indicator
J0_b1=AFCS_->inputs.TCS_button
J1_b5=AFCS_->inputs.GA_button
  Is there a way to accomplish these assignments with what is currently installed ?
Thank you,
Ken
First off, yes, these commands should work, except the first one. If you are just looking for a normal AP disengage (so if you press the button once the AP disengages and the second time you hit the button, the advisory goes out), then I would recommend to use Jx_by=AFCS_->inputs.AP_disengage instead. Works like a charm.
And furthermore, the VariablesMap.xlsx has multiple sheets, also including the AFCS assignments you mentioned, except the first one.
I have excel, but don't use it much and not sure how to access
the other sheets. I'll try to figure it out ~:)
Many thanks for the info, the tips and the recommendation.
Best regards,
Ken
OMG(osh) , What a treasure trove !! Thanks again for the tips.
Ken
Sorry to bump an old thread. This is the most recent one I could find doing a quick search.
Today I tried to assign two buttons using the mjc84.ini file:
J0_b10=AFCS_->inputs.AP_disengage
J0_b2=AFCS_->inputs.GA_button
For some reason, the above inputs seem not to work in my simulation (P3Dv4.4 with the 1.020a Pilot version). I have three game controllers (all USB) in total, and I tried everything from "J0" to "J3". No luck.
Is there anything else I will have to observe in order to make these button assignments work?
For what it's worth: other changes in the *.ini file, such as LBS vs. KGS etc. work flawlessly.
Thanks for any advice.
Oliver
Oliver,
Are you positive you have the right button numbers? Majestic starts at b0 so you might need to apply a -1 offset to match.
Oliver
