Pitch Trim Assignment
What key/joystick assignments should I be using for elevator trim control? I currently have the default P3D trim nose up/down assignments assigned to my joystick. Trim up works fine but trimming down activates TCS and changes the the pitch FMA to "Pitch hold"...
Is there a separate assignment I should use to avoid using TCS when trimming the nose down?
Many thanks.
In the mjc84.ini file you probably have the button for trim down assigned to TCS as well as having it assigned to trim down in the sim.
Check the mjc84.ini file under [JOYSTICK_INTERFACE_ASSIGNMENTS]
In the docs folder there's a doc explaining this section of the ini file. Not at my sim computer now, but I think it is called special features or something like that.
