Tiller Axis full right
Hello!
As you can see in the screenshot - the tiller is full deflected right, but not my ailerons my warthog joystick. Already checked that there is no conflicting axis assigned, no axis via FSUIPC assigned.
Thank you!
Hello!
Thank you!
Solved it by putting 32768 into the field for the Tiller center. This number is the center value for the ailerons.
As the tooltip says when hovering mouse over, I thought that the tiller axis is ignored when "Ailerons+Mouse" is selected... seems not.
