Dear Colleagues !
Is the LUA script "V-Speed Calculator LUA 1.2" compatible with P3D v5 ? For previous versions of simulators two files of the script are to be placed into P3D\Modules folder which is not presented in P3D v5. Should I put them the into FSUPIC folder ?
Thanks !
Yes, Put them in the main FSUIPC directory. Works fine in V5
Unfortunately I cannot confirm this!
FSUIPC has created the folder "Prepar3D v5 Add-ons" and installed itself in it.
Although both files Q400VSpeeds.lua and speeds.dat exist in the FSUIPC6 folder and are used in Key Presses
Lua Q400VSpeeds are set, the speeds are not displayed.
http://majesticsoftware.com/forums/discussion/894/standalone-v-speed-calculator-and-setter-xml-gauge#latest
