No Rudder working in P3Dv5
Hi
I have an issue where no matter what I try the rudder won't work , the only time i can is with the ready for take off preset,.. i tried boarding .. Ready for taxi .. No rudder movement, i use a T16000m using the twist axis for the rudder, all other A/C work fine.. which means i cannot fly the Dash 8 in P3Dv5.... any ideas?
Rich
Update .. Tried it in P3D4.5 same setting ready for taxi and the rudder works fine … So something in the P3Dv5 version is stopping the rudder working.
Hi Keenrw,
I have a suggestion, check in the Q400 ini folder/file to see if the "auto rudder" has been set to on. Be sure to double check your simulators settings, as you will find an "auto rudder" setting in there too.
The ini file should read AUTO_RUDDER_FACTOR =0.0.
Cheers, Jax
Update 2 ...... reinstalled it and now the rudder is all working now so maybe a gremlin crept in during the installation
