Thats it, the red circle.
You prepare the configuration around XULTA to have the aircraft ready to start the final descent.
When you do the descent manually with V/S you start about 0.3 Nm before the TOD and adjust (if necessary) the ROD every Nm.
If i put flap 10 before gear down i get alert sound.
Quite normal, it is designed that way. Flaps 5, then gear down and then flaps 15 (you usually do not use flaps 10 for landing). On my first picture I made a typo, please read flaps 5 instead of 15).
And you say flap 15 3 NM before TOD you put flap 15 10 NM before TOD.
It is what I did (picture 2) 9.2 Nm from Rwy. As said above, typo first picture.
Why you descent with V/S instead VNAV PATH ?
To have a smoother descent exactly at the TOD instead of having a "roller coaster" decent as I explained in an above post.
Before SELAP are you at
flap 5 ?
Just reaching SELAP during the turn towards RONTA
And then do you get down gear before flap 15 ?
Yes, it is the procedure.
Do you pass from direct flap 5 at 15 ?
No flap 10 before ?
http://majesticsoftware.com/forums/discussion/927/traffic-patterns-flight-profiles-in-general#latest
IAF and FAF have nothing to do with the final descent.
By following the above (Flybe), 3 nm from TOD you prepare the aircraft to be ready for the final descent.
If you do it too early you are going to use more TRQ and more fuel as you'll have more drag.
If you do it too late you are not going to be ready on time for your descent and you'll have to increase your ROD to follow the path.
What your TOD ?
I don't understand.
TOD = Top of Descent
the TOD of your final descent when you are going to land.
In your ex: CYYZ around RONTA and CYUL around XULTA
I manage to get some screen shots as I could not do a video.
The FMS are LNAV for the PF and DTO Rwy 05 for the PNF to give the distance to the PF and check the ALT.
I am using Hpa which is not as accurate as Inches of Hg which could explain that some altitudes are not spot on as there are 28 ft between each Hpa.
End of downwind leg arriving at SELAP turning towards RONTA. Flaps 15
About 3 Nm before TOD. Gear - Flaps 15 - RDC Np ldg
0.2 Nm before TOD GS 145 Kt V/S 800 Ft/mn
6 Nm 70 Ft below. Adjusting V/S 700 Ft/mn
5 Nm 90 Ft below. Adjusting V/S 600 Ft/mn. GS reducing to 131 Kt
4 Nm 90 Ft below. Keeping V/S 600 Ft/mn as reducing speed G/S 122 kt
3 Nm 70 ft below. Adjusting V/S 500 Ft/mn
2 Nm 20 ft below. No adjustment of the V/S as reducing the IAS to Vref+5
1.3 Nm 10 ft above MDA. Vref+5. Minimums
These screen shots are only a small part of my set up as I use 3 screens and they won't fit in the pages of the forum.
flap 5 ?
No flap 10 before ?
That's it.
Thank you so much for your help.😀
C'est toujours un plaisir d'aider un lointain cousin du Québec.
