Go around
13»
  • I manage to get some screen shots as I could not do a video.
    The FMS are LNAV for the PF and DTO Rwy 05 for the PNF to give the distance to the PF and check the ALT.
    I am using Hpa which is not as accurate as Inches of Hg which could explain that some altitudes are not spot on as there are 28 ft between each Hpa.
    End of downwind leg arriving at SELAP turning towards RONTA. Flaps 15
    About 3 Nm before TOD. Gear - Flaps 15 - RDC Np ldg
    0.2 Nm before TOD GS 145 Kt V/S 800 Ft/mn
    6 Nm 70 Ft below. Adjusting V/S 700 Ft/mn
    5 Nm 90 Ft below. Adjusting V/S 600 Ft/mn. GS reducing to 131 Kt
    4 Nm 90 Ft below. Keeping V/S 600 Ft/mn as reducing speed G/S 122 kt
    3 Nm 70 ft below. Adjusting V/S 500 Ft/mn
    2 Nm 20 ft below. No adjustment of the V/S as reducing the IAS to Vref+5
    1.3 Nm 10 ft above MDA. Vref+5. Minimums
    These screen shots are only a small part of my set up as I use 3 screens and they won't fit in the pages of the forum.
  • If i put flap 10 before gear down i get alert sound.
  • And you say flap 15 3 NM before TOD you put flap 15 10 NM before TOD.
  • Why you descent with V/S instead VNAV PATH ?
  • Before SELAP are you at
    flap 5 ?
    And then do you get down gear before flap 15 ?
    Do you pass from direct flap 5 at 15 ?
    No flap 10 before ?
    Quite normal, it is designed that way. Flaps 5, then gear down and then flaps 15 (you usually do not use flaps 10 for landing). On my first picture I made a typo, please read flaps 5 instead of 15).
    It is what I did (picture 2) 9.2 Nm from Rwy. As said above, typo first picture.
    To have a smoother descent exactly at the TOD instead of having a "roller coaster" decent as I explained in an above post.
    flap 5 ?
    Just reaching SELAP during the turn towards RONTA
    Yes, it is the procedure.
    No flap 10 before ?
    That's it.
  • Ok super understand now.
    Thank you so much for your help.😀
  • C'est toujours un plaisir d'aider un lointain cousin du Québec.
