Panel popups [RESOLVED by OP]
By default, the FMS popup opens at the top left of the screen. I would like to move this FMS popup to the bottom right for not having to do it manually with each flight. This position suits me better. What settings do I have to change in the panel.cfg to get this default result?
zinj
Solved !
I found the values to change that suit me in the panel.cfg. . If anyone is interested, but I do not know if it will work for all screen resolutions.
[Window17]
window_pos = 0.755, 0.55
zinj
