How do I set up failures in the Majestic Dash 8 Q400 PRO version
Hi guys. I just bought the PRO version so that I could use the failures functionality. I can't work out how to set up the failures. I am not an expert on programming etc but it appears that I need to do something more than just set them up in the MSFS X standard failures panel. Please help
  • edited January 30
    I also seem to have an engine fire on startup by default and cant put it out, even if I follow the correct procedure. ( I am an actual Dash 8 pilot)
