Holdings
When I have to enter a Holding, I define this Holding under Manoevers. So far no problem. But when reaching the Holding point, how can I then start the predefined procedure?
Go DTO holding
Sorry but this doesnt help me as the Holding is not part of my Flightplan. My example: Approaching NZWK Rwy 27 I have to perform a Holding at IAF Regat. Regat is part of my flightplan but the FMS passes Regat and continues the approach to NZWK. How can I start at Regat my predefined Holding procedure? Thats my question.
On the lower left of the Holding Define page is an ARM HOLDING button. You push that after you have defined the pattern.
Sounds good, veeze, but I cant find an ARM Holding button. On the left side of this page is only "Inb/ Dir/Turn", in the middle a drawing of the Holding, on th right side "Direct Entry". More advice is welcome! Thanks in advance!
