Map Lights via XML IF not working
P3D 5.2 HF1, Q400 latest version: I wanted to trigger the map lights (Capt + FO) via the XML interface. But they don't work. According to the variables list, these two variables should control the lights:
electricsData_->control.instlight_leftmap (=88774)
electricsData_->control.instlight_rightmap (=93551)
But the switch is not reacting to these commands. Other instrument lights work as expected. There are also two Lvars:
L:Q400_LT_MAP_LEFT_LT = 0
L:Q400_LT_MAP_LEFT_SW = 0
L:Q400_LT_MAP_RIGHT_LT = 0
L:Q400_LT_MAP_RIGHT_SW = 0
If I trigger the switch by the mouse, the lights are turning on and off. But the SW Lvars are not changing.
Could anyone confirm, that these controls are not working?
  • They are not simulated, since we do not have a real light effect for these lights. They are essentially bogus lights
    Thanks - now it's cĺear. It's a little bit misleading, that there are controls in the interface, and that they light up, if you turn them on using the mouse.
    Best regards
